Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android
Page 8 of 36 <123 ... 789 ... 343536>
Dave1946
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Did you use an ordinary webcam Pete?
Post #289840 30th Oct 2014 8:42pm
Yeah, I got it with the unit from Erisin.... was less than a tenner.... pretty good pic though.... tried loads of variations on daily roads but it would only take pics, not video.... Pete
-Click here for Thread-
Post #289843 30th Oct 2014 8:56pm
hex
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
Haylands wrote:
There is a music App on it that just looks in the right hand sd card for music, you can toggle to it with the bottom button (well, not the phone button, the one above) on the steering wheel, it toggles through the radio/video/dvd/music etc etc, the track advance buttons work with it as well...
The other card works fine, my camera thingy created it's own folder and just sticks it's files in there so it doesn't interfere with anything else on the card, and I presume it just uses up the free space on the card until it's full....
I tried the Daily roads voyager but can't configure it (got bored and gave up actually) for my cheap as chips web cam so I'm using the App that was on the unit from the factory....
you can change where the music app looks for songs
select the music app
it should open ad look like this
select the folder option
then you will see this and you can select the storage where the music is Smile
as you can see I have the gps card the sdcard and a usb connected
it should auto play when you select the folder
Post #289946 31st Oct 2014 12:41pm
I guessed there must be a way.... just never had the time to fully explore what it will do, the manual is very basic and I've never had an Android device before
Thanks for taking the time to do that.... I like your backdrop, thought it was the reflection of a FF parked on your front seat!!!! Pete
Post #289959 31st Oct 2014 2:50pm
hex
this is it
just working on a Range rover splash screen for the start up image
Post #289968 31st Oct 2014 3:19pm
Do show us when you've done it.... Pete
Post #289970 31st Oct 2014 3:25pm
hex
first go at it just to make sure its the correct format and size
bad picture as its dark Sad
Post #290030 31st Oct 2014 8:17pm
Dave1946
That's extremely helpful Hex. Now I can play music from the dash USB as I'd planned!
By any chance has anyone managed to get a reply from messages sent to Erisin?
I've sent three over the last month, via their web site, and had no replies. I also tried phoning the UK number but got a message to say that it wasn't a working line!
I wanted to buy one of their cameras (ES550, the one listed with the ES9753A) but there is no way of adding it to a shopping basket. I know, I know, I should have got it with the head unit.
Post #290039 31st Oct 2014 8:54pm
It's just a cheap USB web cam, there must be loads on ebay....
Try emailing Crystal at erisintechservice@erisin.com it usually takes a few days for a reply but I've always had one.... Pete
Post #290040 31st Oct 2014 9:01pm
mjdronfield
So you could possibly wire in a USB switch box and a long extension lead, allowing you to have another web cam on a suction mount that you could stick anywhere on the vehicle when off roading etc...... Like a Venturecam.......
That head unit seems very versatile.......
Though it could be easier wirelessly with your mobile phone, without using the car at all......
Thinking aloud again....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #290042 31st Oct 2014 9:09pm
Dave1946
There are loads of usb webcams on eBay Pete, but they all seem to need connecting to Microsoft to work.
I bought a cheap one from PC World but the head unit wouldn't see it. It came with an installation disc for windows and works fine on my laptop though.
When I bought it I told the guy what I wanted it for and he didn't think that it would work with Android; he was correct!
Post #290056 31st Oct 2014 9:39pm
hex
I am working on a multi can android app for it using the reversing cam and a USB cam its working but has a few bugs
The good thing is they have included USB drivers in the base android system which is normally an issue, I will get a USB hub and see how many devices it supports
I will post up some links over the next few days once I work out why the front can insist on being upside down even when you turn it Big Cry
Post #290058 31st Oct 2014 9:46pm
Have you tried this
https://play.google.com/store/apps/details....usbcamera Pete
Post #290059 31st Oct 2014 9:47pm
Dave1946
I'm beginning to think that there is a fault with this unit of mine.
Whatever I try, the USB ports will not accept music from a memory stick.
Now I've noticed that when my new webcam is working on the laptop a little switch, which is for taking a still image, is lit.
But on the head unit it isn't.
Shouldn't there be a voltage pos and neg on two of the four connections in a USB socket?
Post #290064 31st Oct 2014 10:12pm
hex
Dave
plug it in the find the file browser you should se the usb device listed.
I can post a step by step guide if you like
Paul
Post #290065 31st Oct 2014 10:24pm
