Home > Maintenance & Mods (L322) > L322 air con pressure help
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
My air con isn't working very well. When turned off the pressure as read by my plug in diagnostic tool is about 9. When engaged it goes up very slightly to about 9.5 ( no indication of units). Would anybody with an L322 and the diagnostics mind checking theirs? I believe it is the compressor which is faulty.
MC
Post #294462 20th Nov 2014 10:29pm
Are you sure it just doesn't need re-gassed? Got - 2017 SDV8 Autobiography in Loire Blue
Post #294463 20th Nov 2014 10:33pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Is the passenger side vents colder than the driver side.
Mine was like this. Halford regas 44 quid just sorted it
.. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #294464 20th Nov 2014 10:38pm
could be the condenser leaking, its right at the front and liable to get hit by stones and road debris... ... - .- -.
Post #294466 20th Nov 2014 10:45pm
Mistercorn
I had it regassed, it appears to have pressure, it just doesn't change much when turned on. That said I am not sure what the pressure should be. Hence my request for somebody with a working one to check.
MC
Post #294470 20th Nov 2014 10:51pm
johnboyairey
its a no-brainer to get it regassed, because, (at least they used to) they guarantee that if it doesn't get colder by about 4 degress. its free. also, if you need a condenser, because of no gas pressure, and leak etc. they are about £90 on ebay. if you need the pump, they are on ebay for about £225 new both not the hardest things to change, but I did mine and removed water rad at same time. the gas also has a lube in it.
its a good idea, to leak test all the joints as soon as you get it back from aircon guy, so you can fairy liquid and paintbrush the joints and see any leaks. obviously you wont see it when its all gone. mine is also a 2002 v8. and they use the same pump as the x5
Post #294472 20th Nov 2014 10:57pm
Mistercorn
It did have a leaky condenser, which was changed. I then had it regassed. It held the vacuum but they had trouble regassing it and afterwards it wasn't getting colder so I wasn't charged. I have got a spare compressor but want to check the pressures with known good ones before paying to have it changed. I can't think what else it can be.
MC
Post #294474 20th Nov 2014 11:02pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I did a post 18 months ago and posted my pressure values.
Post #294481 21st Nov 2014 12:08am
Mistercorn
I have found it, it looks like you were seeing about 15-16 when turned on, but still no values for when it was off. Thanks very much though, half way there.
MC
Post #294490 21st Nov 2014 8:23am
johnboyairey
is your pump clutch engaging? you might see it spin up when turned on. with a torch placed. -mind your hands on the belt though.
Post #294500 21st Nov 2014 10:49am
Mistercorn
Yes it is engaging, the pressure does change slightly and it can be seen to be engaging.
MC
Post #294501 21st Nov 2014 10:51am
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Looking for answers off this post, my system was gassed perfectly last summer and has worked well up until now. My Gap tool reads 6.5 , I presume that’s psi, so maybe low, that’s why I on this thread to see exactly what pressure should be there. I cannot find the the link by Katash to see the pressures posted by himself , that’s why I am on here. Halfords will not let me have a refill can as my compressor is not turning , so my call to them is that by charging the system with the can this will start the compressor , their gauge shows low .... but ? I have a manifold system to monitor gassing in and in the past I have used these cans to restart the compressors, so I am a bit stuck unless I do some ground work. So pressures please!
Post #477829 9th May 2018 12:48pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
if I remember correctly, I put 35lb in mine with the engine doing about 1100 RPM RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #477833 9th May 2018 2:16pm
alfapat
So about 7kg not much needed but how much to start with and was the compressor going before you did it?
Post #477879 9th May 2018 9:56pm
knares
Sorry I didn’t make that very clear.
I connect up the gauge ect, start the engine, turned on the gas just a little and let it slowly flow in to the system.
I only use the blue gauge and connector fitting
Once there is enough pressure the compressor should start.
With the engine running at about 1100rpm, I let the pressure build up to 35psi.
I am no expert but I have been doing it like that on all my vehicles for a number of years.
If you put to much pressure in the system it cannot work properly RR 2005 4.4 petrol
Post #477892 10th May 2018 2:48am
