![]() | Home > Maintenance & Mods (L322) > L322 air con pressure help |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6795 ![]() ![]() ![]() |
Are you sure it just doesn't need re-gassed? Got - 2017 SDV8 Autobiography in Loire Blue
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Is the passenger side vents colder than the driver side.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35703 ![]() ![]() |
could be the condenser leaking, its right at the front and liable to get hit by stones and road debris... ... - .- -.
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
I had it regassed, it appears to have pressure, it just doesn't change much when turned on. That said I am not sure what the pressure should be. Hence my request for somebody with a working one to check.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
its a no-brainer to get it regassed, because, (at least they used to) they guarantee that if it doesn't get colder by about 4 degress. its free. also, if you need a condenser, because of no gas pressure, and leak etc. they are about £90 on ebay. if you need the pump, they are on ebay for about £225 new both not the hardest things to change, but I did mine and removed water rad at same time. the gas also has a lube in it.
It did have a leaky condenser, which was changed. I then had it regassed. It held the vacuum but they had trouble regassing it and afterwards it wasn't getting colder so I wasn't charged. I have got a spare compressor but want to check the pressures with known good ones before paying to have it changed. I can't think what else it can be.
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
I did a post 18 months ago and posted my pressure values. |
I have found it, it looks like you were seeing about 15-16 when turned on, but still no values for when it was off. Thanks very much though, half way there.
is your pump clutch engaging? you might see it spin up when turned on. with a torch placed. -mind your hands on the belt though. |
Yes it is engaging, the pressure does change slightly and it can be seen to be engaging.
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Looking for answers off this post, my system was gassed perfectly last summer and has worked well up until now. My Gap tool reads 6.5 , I presume that’s psi, so maybe low, that’s why I on this thread to see exactly what pressure should be there. I cannot find the the link by Katash to see the pressures posted by himself , that’s why I am on here. Halfords will not let me have a refill can as my compressor is not turning , so my call to them is that by charging the system with the can this will start the compressor , their gauge shows low .... but ? I have a manifold system to monitor gassing in and in the past I have used these cans to restart the compressors, so I am a bit stuck unless I do some ground work. So pressures please! |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 798 ![]() ![]() ![]() |
if I remember correctly, I put 35lb in mine with the engine doing about 1100 RPM RR 2005 4.4 petrol
So about 7kg not much needed but how much to start with and was the compressor going before you did it? |
Sorry I didn’t make that very clear.
