![]() | Home > Technical (L322) > PCB for Fuel Burning Heater? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
I seem to recall reading its part of the FBH. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
pretty sure its integral to the control unit/heat exchanger on the FBH, so you will need to get under the wheel arch. |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Yep I sent mine to France last year.
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
Yep fbh is behind the left front wheel, below the battery. The PCB is on top of the fbh heater, but has to come out to get it !!! |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Thanks Chaps,
Yep. Need to patch the flow and return lines together then top up coolant. Squeeze off the hoses before you remove it to reduce the coolant loss. |
Thanks for the tips chaps ,
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
i am sure somebody on here said that the pcb can be removed from the top without removing the whole fbh |
Yes me too,
