Home > Technical (L322) > PCB for Fuel Burning Heater?
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Ok, found time to Look into this PCB today and was going to remove it and send to French MIke after suggestions to do so on here ........but where the hell is the little black box containing the FBH PCB ? ,
looking at other posts and pictures I thought it was in front of the battery on nearside .....I have nothing resembling this black box
I have done a search but cannot find any posts showing where it actually is can anyone help as it's getting dark now and I'm running out of time ..
Big Cry
Post #297007 4th Dec 2014 6:20pm
Andy
I seem to recall reading its part of the FBH.
Post #297008 4th Dec 2014 6:22pm
pretty sure its integral to the control unit/heat exchanger on the FBH, so you will need to get under the wheel arch. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #297010 4th Dec 2014 6:29pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Yep I sent mine to France last year.
You need to remove the FBH from behing the passenger wheel arch.
Join the two hoses with copper to complete the circuit, then take the pcb out from the FBH and send it off.
Post #297011 4th Dec 2014 6:38pm
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Yep fbh is behind the left front wheel, below the battery. The PCB is on top of the fbh heater, but has to come out to get it !!!
Post #297074 4th Dec 2014 10:05pm
J evro
Thanks Chaps,
Thought it was to good to be true when I heard it was right on top in front of battery ......
I presume it will empty of water then when removed ?
Bow down
Post #297114 5th Dec 2014 3:16am
Yep. Need to patch the flow and return lines together then top up coolant. Squeeze off the hoses before you remove it to reduce the coolant loss. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #297294 6th Dec 2014 9:35am
J evro
Thanks for the tips chaps ,
Is there any way you can get to this by removing the battery and tray as I only need to get at the top part to remove the PCB for French Mike (I'm not with the car so cannot check)
Presuming it's this type of FBH and I need to grit into one of the black boxes on top ?
Post #297367 6th Dec 2014 6:37pm
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
i am sure somebody on here said that the pcb can be removed from the top without removing the whole fbh
Post #297442 7th Dec 2014 10:29am
J evro
Yes me too,
I've tried a search but haven't found it ..
Anyone confirm if it can be removed from above without disconnecting the Webasto ?
Post #297464 7th Dec 2014 12:59pm
