![]() | Home > Technical (L322) > L322 VANOS solenoid |
| tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
yes, l appreciate you pain! i did mine outside, as that was where it was! in that everlasting frozen January a couple of years back, so i could only manage a few hours at a time, without cold hand fatigue, and anger setting in! i just would not drive it till its sorted my friend. you are on a 'cliff-edge' here... if you toast it, you are looking at more work to change engine, and the lump will be £2000 and will have similar 'cliff-edge' potential chains waiting to, 'go'
| Trossachsturbo Member Since: 29 Jan 2014 Location: Central Posts: 24
A great write up, and confidence booster for anyone with one of these amazing old vehicles!! |
edit, well i couldn't do better pics than this guy has done, this IS whats required to do the full job,
Excellent post. thanks.
hi again, you are doing the right thing!
Went to my usual guy and he said no... |
you could do nothing better than to go across to the dark side and visit a bmw forum, |
Local BMW indy wants £1800 to replace just about everything under the timing chain covers... whilst in some books that's a sensible procedure - it's not happening!
by all means order and do the job yourself.... but mate, buy the tools!
| Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419
As said above you need more than a block a wood to hold the cams due to the VANOS. The blocks of wood in a video you mentioned are for the older NON VANOS M62. You need the proper tools to hold and set the VANOS in the correct position otherwise you could just be throwing money away when valves meet pistons...ouch! Don't f*** it up for the sake of £70 hire cost for the full set of tools (check ebay for hire costs, or contact Phoenix Motorsport).
Thanks guys, this is getting worse by the minute... |
...or tools to rent via ebay for £70... don't think this is going to happen as soon as I would like though...
there's never a good time to throw a grand at a motor, especially at Christmas, but have you considered my previous idea? take your time, (this took 2 mins) and just buy an old sh!tter to drive, till you can do a proper job, and have plenty of time/weather to do it! something like this, but local to you..... http://www.ebay.co.uk/itm/Ford-Mondeo-mk2-...7675.l2557
