Home > Maintenance & Mods (L322) > WARNING change your diff oil!!!
Page 2 of 10 <12345678910>
verydisco wrote:
Mark C
either you check on Topix, possibly even the owner's manual prior to ordering the oils or when filling, you fill up until it goes out the filling hole.
Not strictly true J... You need to check capacities on "Topix" as some take an amount rather than fill to top Thumbs Up
Post #299373 16th Dec 2014 11:23pm
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
I couldn't find the exact amount that they take. I was just going to measure exactly how much comes out and put the same amount back In. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #299377 16th Dec 2014 11:33pm
noworries4x4
Where my Defenders spend long durations on motorways the rear axle gets hot and then cold at night the condensation water in my oil is horrid, every 24thou milky soup taken out. If everything is under control you are not going fast enough.
MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
MY 12 Full Fat 4.4 TDV8
1952 Series 1 80" 3ltr 6cyl
Post #299382 16th Dec 2014 11:56pm
Did my front and rear ages ago not long after I started with it so before 130k and now on 150k and it was horrid stuff! Ended up at the local recycling place. Hate to think where it all ends up... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #299387 17th Dec 2014 1:00am
pld118
Sorry if I've missed this but I read reference to someone saying it's easier to do this on a ramp, as you might expect. If DIY though, is access to the front and rear diffs easy and safe enough to do this job with the car just on axle stands?
One other daft question... I know Craig said no need to warm the diff oil up before removal but how would you warm it up anyway?
Thanks Thumbs Up
Post #300195 21st Dec 2014 9:41am
you could possibly do this in off road height with the correct precautions but i'm sure someone [craig?] said that the FF has to be level so one end on axle stands wont work..
i should think a short journey will warm up the oil.. ... - .- -.
Post #300206 21st Dec 2014 11:12am
A short drive of say 10-15mins should get some heat into them or just use a blow torch to gently heat them up. Then just use an ice cube on each of the nuts to cool them more than the rest of the diff and this can help removal of stubborn ones 😊 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #300207 21st Dec 2014 11:15am
Stan is right, a drive will warm up the diffs Thumbs Up
Yes the job could be done on axle stands but the car does not need to be level (as your diff takes a quantity of oil, not to a level) Thumbs Up
Post #300208 21st Dec 2014 11:15am
Embarassed my bad re the 'level' suggestion.. ... - .- -.
Post #300209 21st Dec 2014 11:18am
Shocked Shocked Shocked imho theres far too much rubber, gaskets, seals, gaters & alike around there to suggest a novice takes to it with a "blowtorch" Will!
Sorry but just my opinion sir Thumbs Up
Post #300210 21st Dec 2014 11:19am
Like anything blowtorch related, it takes care and not a gung Ho clarkson style approach Smile
It only needs a little bit of warmth to make the oil thinner, especially in this weather but if you don't feel 100% that you can contain your inner fire starter best to use the short drive method 😄😄👍👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #300211 21st Dec 2014 11:22am
Laughing Laughing Laughing Thumbs Up
Post #300213 21st Dec 2014 11:35am
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Any idea what the difference in quantity of oil is between the set amount they're meant to take and the filler point...?
I ask as we filled mine to the filler plug level when we changed it last month...
Post #300216 21st Dec 2014 11:40am
Rolling Eyes Rolling Eyes Rolling Eyes DIY'ers Rolling Eyes Rolling Eyes Rolling Eyes Laughing Laughing Laughing
Drain it into a container and put back in the correct amount Thumbs Up
Must be important otherwise JLR would just tell you to fill to drain level Thumbs Up Thumbs Up Thumbs Up
Post #300217 21st Dec 2014 11:44am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Craig
would appreciate your thoughts on fluid changes generally
my MY11 is only 4 yrs old now. around 30k mileage.
Would you recommend changing diff oil now?
other oils...
transfer box oil
axle oil
transmission / gearbox oil
LR say these should be done either at 5 years (diff and transfer) or 9 / 10 years (axle and transmission)
speak to a few LR garages however and they say transmissions are sealed units - you dont change the oil in them
is it worth while next year, when car may have 40K miles to change the whole lot ?
money not an issue - but will i be achieving anything?
or should i just change the transfer box and diff oils?
happy chrimbo !
Post #300541 23rd Dec 2014 8:57am
