![]() | Home > Maintenance & Mods (L322) > WARNING change your diff oil!!! |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Take it to the dump for recycling. Alternatively...... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
where's the oil residue from ryan? ... - .- -.
WD40 Stan... The residue/ deposits are only the results of my prep for when I eventually buy the correct tools to undo the plugs! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
This is also a useful set to have
Done it! Rear Diff oil changed today, by me |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
did the syringe do the job then ? did you take the car a run first to heat the oil ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 361 ![]() ![]() ![]() |
This is the tool to help fill both front & rear difs
How much debris was on the magnet? The DARK BROWN colour is rust ![]() ![]() |
Craig, the magnetic part of the drain plug (both filler and drain plug faces actually were/ seemed) surprisingly clean, although the threads needed a clean.
Mark,
Its amazing how the rear diff oil degrades isn't it ![]() The colour will be down to the internals of your diff rusting due to water ingress (i suspect condensation) then its only a matter of time before A, the bearings give up! and the rust makes the driveshaft seals blow! Good job you caught it when you did sir ![]() |
nice one Ryan, hopefully my stuff will arrive tomorrow.
I did Mark yes but its A, my weekend off sir & B, been a dreadful weekend (personal) so NO SIR i have not & don't intend answering until the morning sir |
Craig, would you hope that this oil change (plus future 30k mile changes) should 'save the diff' if the brown coloured oil might be indicative of condensation build up rust that could lead to failed bearings and driveshaft seals? Thanks. |
