|  | Home > Maintenance & Mods (L322) > Coolant loss but no leak |
| Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951      |
 Ok, I keep getting check coolant level on my dash even though I've just topped up and bled the cooling system. I've pressure tested the system using a Blue Point kit and the gauge does not budge. I've also done a gas test to detect combustion gases and that's coming back clear also.
|  29th Dec 2014 3:10pm |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902      | or you might have a leak when its cooling down as mine did last year.
|  29th Dec 2014 3:59pm |
| jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259      | I thought I'd pass on what little I've learned along the way.
|  29th Dec 2014 7:28pm |
| Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951      | As I said, I've pressure tested it and the dial doesn't budge. At the same time, I can't see anything spraying anywhere. When I was on the spanners some years ago, I used pressure testers a lot. If there was so much as a pin hole anywhere, it would be very obvious very quickly. Sometimes, that pin hole under pressure would get a lot worse and gush out.
|  30th Dec 2014 1:18am |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035      | Have you tried placing a large square of cardboard under the engine, and running it for a bout 20mins, after a run, and then allowing a cool down, the few spots in the cardboard could tell you the place to be looking more closely. | ||
|  30th Dec 2014 1:28am |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672      | In my last TD6 i always had the 'check coolant level' after a long fast run. naturally I did, and the cold levels were always where they should be.
|  30th Dec 2014 12:50pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | I have a similar unsolved coolant loss (but not as bad as yours Noddy, @ 1pt a week, 300 miles driving, but no coolant loss bong)
|  30th Dec 2014 1:46pm |
| markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120      | No sure if the cooling system layout is the same but I had a leak at the back of the engine above the bell housing. There was a very small leak on one of the hoses from the head where they join with a Y jct. It evaportates before it has chance to drip anywhere. | ||
|  30th Dec 2014 2:04pm |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
 However, this doesn't help with coolant loss.
