Home > Maintenance & Mods (L322) > Coolant loss but no leak
Andy
Ok, I keep getting check coolant level on my dash even though I've just topped up and bled the cooling system. I've pressure tested the system using a Blue Point kit and the gauge does not budge. I've also done a gas test to detect combustion gases and that's coming back clear also.
The car is fine for a day or so then I get the message appear and the coolant level has dropped. With no obvious leak, no drop in pressure using a tester, what else could it be?
Post #301628 29th Dec 2014 3:10pm
pld118
Bleed screw not making a proper seal?
Tried putting a new rubber o-ring on it or wrapping plumbers white PTFE tape around the bleed screw thread?
Post #301636 29th Dec 2014 3:50pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
or you might have a leak when its cooling down as mine did last year.
Have a look at this link, any help to you???
http://www.fullfatrr.com/forum/topic23001.html?highlight=o+ring If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #301637 29th Dec 2014 3:59pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
I thought I'd pass on what little I've learned along the way.
Is there any dried coolant around the header tank cap? Mine was weeping here due the the threads on the cap being cracked.
Is there any evidence of dried / wet coolant under the header tank on or around the wing? The connectors underneath can fail too along withy the coolant sensor seal.
Sometimes the expansion header tanks crack slightly and weep coolant too.
The lower corner of the rad is prone to rusting and leaking just enough to lose coolant but most of it evaporates coz of the heat there.
Hope this might help.
Jake 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #301668 29th Dec 2014 7:28pm
Andy
As I said, I've pressure tested it and the dial doesn't budge. At the same time, I can't see anything spraying anywhere. When I was on the spanners some years ago, I used pressure testers a lot. If there was so much as a pin hole anywhere, it would be very obvious very quickly. Sometimes, that pin hole under pressure would get a lot worse and gush out.
I also did a combustion gas test which came back clear. There is no sludge in the engine oil either so I'm confident there is no coolant going into the bores
Post #301753 30th Dec 2014 1:18am
johnboyairey
Have you tried placing a large square of cardboard under the engine, and running it for a bout 20mins, after a run, and then allowing a cool down, the few spots in the cardboard could tell you the place to be looking more closely.
Post #301756 30th Dec 2014 1:28am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
In my last TD6 i always had the 'check coolant level' after a long fast run. naturally I did, and the cold levels were always where they should be.
Sounds to me like a pressure related anomaly and not sign of anything nasty. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #301801 30th Dec 2014 12:50pm
I have a similar unsolved coolant loss (but not as bad as yours Noddy, @ 1pt a week, 300 miles driving, but no coolant loss bong)
No signs anywhere of leakage, newish rad, newish top up tank.
I think it may be from @ the thermostat housing, I was never happy with the refit of the pipes to it.
We did discuss a while back the coolant sensor in the tank, this can be replaced in-situ without drain down, but this issue may be the "site glass" inside the coolant tank which is clouded over. CTC was going to cut an old coolant tank open to verify, but he's a busy boy Thumbs Up However, this doesn't help with coolant loss. .
Post #301810 30th Dec 2014 1:46pm
markcartlidge
No sure if the cooling system layout is the same but I had a leak at the back of the engine above the bell housing. There was a very small leak on one of the hoses from the head where they join with a Y jct. It evaportates before it has chance to drip anywhere.
Post #301812 30th Dec 2014 2:04pm
