![]() | Home > Maintenance & Mods (L322) > Coolant loss but no leak |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Ok, I keep getting check coolant level on my dash even though I've just topped up and bled the cooling system. I've pressure tested the system using a Blue Point kit and the gauge does not budge. I've also done a gas test to detect combustion gases and that's coming back clear also.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
or you might have a leak when its cooling down as mine did last year.
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
I thought I'd pass on what little I've learned along the way.
As I said, I've pressure tested it and the dial doesn't budge. At the same time, I can't see anything spraying anywhere. When I was on the spanners some years ago, I used pressure testers a lot. If there was so much as a pin hole anywhere, it would be very obvious very quickly. Sometimes, that pin hole under pressure would get a lot worse and gush out.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Have you tried placing a large square of cardboard under the engine, and running it for a bout 20mins, after a run, and then allowing a cool down, the few spots in the cardboard could tell you the place to be looking more closely. |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
In my last TD6 i always had the 'check coolant level' after a long fast run. naturally I did, and the cold levels were always where they should be.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I have a similar unsolved coolant loss (but not as bad as yours Noddy, @ 1pt a week, 300 miles driving, but no coolant loss bong)
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
No sure if the cooling system layout is the same but I had a leak at the back of the engine above the bell housing. There was a very small leak on one of the hoses from the head where they join with a Y jct. It evaportates before it has chance to drip anywhere. |
