![]() | Home > Technical (L322) > My 2006 4,2SC. Whistling and Squealing. YouTube Video. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
i reckon belt tensioners and alternator...(only a guess mind) ... - .- -.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1402 ![]() ![]() |
Water pump on its way out?? |
Arkle Member Since: 17 Aug 2014 Location: Cheshire Posts: 173 ![]() ![]() |
Thanks for the replies.
your car profile is missing so i assume you have a 4.2 so here's the bits that are at the front that might be making the noise,
Thanks for that, Stan. I'll take a look later today. |
Sounds unhealthy and not a noise I've heard from ours. Interested to find out what it is.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Can't hear it whilst I am at work, but mine has a whining noise which I am convinced is the alternator. Local dealer says not done many/any alternators on a 4.2! turning on all the lights, heated screens and heater made the noise a lot worse and then almost goes when everything is turned off again.
I have a similar squeel on mine on first starting up , I've come to the conclusion the water pump is on its way out , pump arrived today , does anyone know if its much of a job on the 4.2 s/c or is it a simple whip off and on (I doubt it looking at access |
petrol 4.4 here which cant be that different to the 4.2,
Mine is booked in at DSE LR Services on Wednesday. I'll report back. |
quite different to the 4.4 Stan, looks as if shroud needs to come out which also looks as if aircon refrigerant needs to be dumped , if my mechanic doesn't take it on (mot place who does minor works) looks like a job for the summer to me |
ah ok.. |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 ![]() ![]() ![]() |
My 4.2 S/C also has a slight "chuffing" noise when it is cold, which eases off when it gets warm.
The squeaking is made worse by moist conditions. It was hardly noticeable in the warmer months and would soon abate but the winter weather has seen it worsen and stay even after a good 10 mile run, so in she goes for fear something gives way.
