![]() | Home > Technical (L322) > Bl00dy FBH again |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204
Evening all. PLEASE HELP IF YOU CAN
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
PM LR customer relations on here and ask them to intervene, there should be some master tech then can send to have a look, even heard of them sending the car back to the factory to get fixed....
Cheers Pete
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Not much good suppose but they had mine in in December changed the pump but there was a blockage in the fuel line or I should say one of them which prevented it from working also mine shows no fumes whatsoever when running but it does get warm - good luck |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
They need to check the FBH is actually working when tested directly. The webasto's are easy to do this to as they are simple devices. From there they can then trigger it from the SDD/Testbook (IIRC) and make sure the main control unit for the car is actually sending the signal out.
Craig
| martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256
I had a problem with my FBH on my 2010 Vogue.
| sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 41
The FBH on my ´03 TD6 does not switch on even at temperatures below -10 celsius. Previously I was mistaken that "Pre-heating" indicated FBH as the message would appear when the ambient temperature was below +5 celsius.
| ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355
they can all be tempremental because they dont run for long enough (30 mins is not long enough to get rid of the carbon build up in the burner chamber) they are connected to temp senders ect and have there own failsafe shutdown system if anything is wrong,they are also very voltage reliant.
Chaps
Don't they make US look good Jay |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
I have the batteries in my fob the wrong way round for 11 months of the year so my FBH doesn't run by accident....it's not that complex a system so I'm a tad confused by LR struggling so much |
Don't know how they stay in business Jay...
| All times are GMT |
