![]() | Home > General > What Did You Do In Your Full Fat Today |
| CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
Cleaned the garage up and parked back the beasts (thanks to the IID Tool, dropping the G4 Rangie 2 inches lower than access mode in order to get in !)
| markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316
Does the g4 ride higher than standard ff ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
| Stuntman Member Since: 27 Dec 2014 Location: Norfolk Posts: 67
Looks like the roof rack causes issues! |
Mark, the G4 has a roof rack, spot lights and Plaques, hence why it goes in with the custome access mode |
| Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126
Ordered new front struts and airbags as near side has a hole in it and FUBAR, since the service in November it has had !new low pressure fuel pump, £280, new alternator £236 fitted by self, and now new front struts £598 fitted.
Replaced all engine rubber hoses, thermostat and plugs, then coolant (well I got the specialist to do it |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
After a failed attempt to change the lower ball joints and 1 arm, my mate at the local garage sorted it in just under 2 hours...so nice shiny 2 arms and ball joints fitted...........a press needed for the workshop me thinks and save 97 quid |
Finished of the tints. Well everything but the rear window, got a friend who's going to give me a hand with that at the weekend.
| DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794
MOT today. 108,000 miles. NO advisories !! PASS |
Today mine is having new front struts another £600 😳 2005 Range Rover Vogue with Supercharged Accessories
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
nothing. still sat in garage from wednesday. £67.00 pmonth insurance, 43 pmonth tax - need to use it more often!!! 405 AB exec seats Baltic and Cirrus
| appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424
Yesterday: Bog Standard service at local indy, Niggly coolant leak sorted with jubilee clip. MOT, no advisories! |
| jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259
[quoteYesterday: Bog Standard service at local indy, Niggly coolant leak sorted with jubilee clip. MOT, no advisories! Very Happy[/quote]
