![]() | Home > Technical (L322) > Cubby Box Lid Removal |
| Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301
Hi guys,
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Is it black? |
The top is sand leather, I'm trying to get it off the plastic bit. |
Thanks Craig, does the top cover come off on its own or does it come off with the plastic tray attached? Does the gas strut undo at the top or bottom? |
Take the torx screws out (under the lid) and when all removed lever the lid apart gently and it should pop off leaving you a view of the gas strut end sir |
Thanks, I took all the torx out but one corner seems to be stuck and I was bothered about breaking something if there was something else holding it on. |
Ill go and have a quick look for you Mr Fish |
Thank you very kindly sir |
There are seven torch screws sir |
Excellent, thanks, you're a star |
| Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947
Craig- have you got one in parchment? |
The end result, much better |
