Home > Technical (L322) > Cubby Box Lid Removal |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 |
Hi guys,
21st Jan 2015 8:25pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Is it black? |
21st Jan 2015 9:57pm |
The top is sand leather, I'm trying to get it off the plastic bit. |
21st Jan 2015 10:02pm |
Thanks Craig, does the top cover come off on its own or does it come off with the plastic tray attached? Does the gas strut undo at the top or bottom? |
21st Jan 2015 10:18pm |
Take the torx screws out (under the lid) and when all removed lever the lid apart gently and it should pop off leaving you a view of the gas strut end sir |
21st Jan 2015 10:23pm |
Thanks, I took all the torx out but one corner seems to be stuck and I was bothered about breaking something if there was something else holding it on. |
21st Jan 2015 10:25pm |
Ill go and have a quick look for you Mr Fish |
21st Jan 2015 10:27pm |
Thank you very kindly sir |
21st Jan 2015 10:40pm |
There are seven torch screws sir one is hard to see under the gas strutt |
21st Jan 2015 10:42pm |
Excellent, thanks, you're a star
21st Jan 2015 10:44pm |
21st Jan 2015 10:45pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
Craig- have you got one in parchment? |
21st Jan 2015 11:35pm |
The end result, much better
15th Feb 2015 6:47pm |
