![]() | Home > In Car Electronics (L322) > Ipod |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
thats a no, and here's a few of many threads re this ,
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
No unless the purchaser specced the LR connectivity kit or retrofitted a kit . The connection would normally be in the glove box if so.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8094 ![]() ![]() ![]() |
As you have an SE, there should be an Aux in on the back of the centre console.
Land Rover iPod kit is over 500 GBP now so best look on ebay or have deep pockets .
That looks neat, but Bluetooth is OK for phone calls, but not the best for music. On my boat I have one of
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I have the original LR kit in mine. Bought from Duckworth Dan and fitted in about 2 hours.
Sound isn't top draw on my set up but its better than an FM modulator and it's quick neat and relatively cheep .
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
David, for a cheap solution (not integrated with the touchscreen) you can use the rear Aux input on the SE and keep everything tidied away in the centre cubby hole
Also worth noting if you're new to iPods and speakers (vs headphones) is that you need a decent quality rip. If you use a low bit rate - like 128k which used to be the iTunes & Apple store standard, then it will be somewhat lacking in the bass department.
