Home > In Car Electronics (L322) > Ipod
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Ipod
Hi guys,
Can anyone tell me if my 07 plate 322 has the connection for iPod?
Pick car up on Monday, and if not, what do I need to make it work??
Thanks in advance
David
Post #311333 7th Feb 2015 12:02pm
thats a no, and here's a few of many threads re this ,
http://www.fullfatrr.com/forum/topic30076.html?highlight=ipod
http://www.fullfatrr.com/forum/topic27785.html?highlight=ipod ... - .- -.
Post #311334 7th Feb 2015 12:08pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
No unless the purchaser specced the LR connectivity kit or retrofitted a kit . The connection would normally be in the glove box if so.
A proper LR kit is circa £475 and can be diy fitted GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #311335 7th Feb 2015 12:10pm
As you have an SE, there should be an Aux in on the back of the centre console.
The easiest solution is a lead like this plugged into one of these
I had this set up then upgraded to the full integrated kit - which IMHO wasn't worth it.
Post #311338 7th Feb 2015 12:18pm
Land Rover iPod kit is over 500 GBP now so best look on ebay or have deep pockets .
I have a relatively cheap solution that is a bit neater than the aux cable rout , I fitted a Grffin Blue Trip to the aux socket and power socket and now stream my music from my pocket so to speak .
http://www.amazon.com/Griffin-Technology-B...B004KPLS7K 2008 MY Supercharged
Post #311375 7th Feb 2015 3:47pm
That looks neat, but Bluetooth is OK for phone calls, but not the best for music. On my boat I have one of
these which use airplay over wifi which is better quality Thumbs Up
I (maybe incorrectly) interpreted the request for a good old fashioned iPod - because that's what I have in the car - that supports neither bluetooth to airplay Sad
FWIW, the official fully integrated solution displays song titles, and uses the skip type controls on the screen & steering wheel - but it only supports the first 5 playlists. It basically replaces the CD player as far as the audio system is concerned - CD6 is everything on the device.
There is no search functionality or anything like that - so you get basic control and can put the iPod out of the way in the glovebox.
Post #311378 7th Feb 2015 4:08pm
n1cktdv8
I have the original LR kit in mine. Bought from Duckworth Dan and fitted in about 2 hours.
I like the original kit as I didnt want extra brackets and cables on display but I wouldn't say it's very good. It emulates the existing 6 disc CD changer, so you have to set up 6 playlists on your ipod and use them as if they were CD's. There is no search function either. Not great tbh. Is this where I put the car details and a bit about myself ?........
Post #311382 7th Feb 2015 4:51pm
Sound isn't top draw on my set up but its better than an FM modulator and it's quick neat and relatively cheep .
Bad news for the future is that manufacturers are all going to be using bluetooth streaming for connectivity . 2008 MY Supercharged
Post #311464 8th Feb 2015 2:13am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
David, for a cheap solution (not integrated with the touchscreen) you can use the rear Aux input on the SE and keep everything tidied away in the centre cubby hole
This is what i did to enable bluetooth streaming from my phone
http://www.fullfatrr.com/forum/topic24633.html 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #311484 8th Feb 2015 10:59am
Also worth noting if you're new to iPods and speakers (vs headphones) is that you need a decent quality rip. If you use a low bit rate - like 128k which used to be the iTunes & Apple store standard, then it will be somewhat lacking in the bass department.
Some people insist that you need full loss-less ripping - I find that 320k is good enough for me Thumbs Up
Post #311490 8th Feb 2015 11:32am
