![]() | Home > Technical (L322) > HEATED STEERING WHEEL L322 VOGUE |
v8rich Member Since: 28 Dec 2013 Location: Healing, Lincolnshire Posts: 67 ![]() ![]() ![]() |
I'm after a heated wheel 'ecu', for the final piece in my heated wheel upgrade.. |
Righto, will keep an eye out for that. It's a bit lower down the priority list atm. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Thanks Mate, you've made my day |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2283 ![]() ![]() ![]() |
Mine stays on till either switched of or ignition turned off and like Pete the stitching doesn't get too hot was only complaining to SWMBO about that this morning |
Slow Member Since: 09 May 2015 Location: Inverness Posts: 39 ![]() ![]() ![]() |
Bit of a thread revival but, my heated steering wheel does exactly what you described. Press it on and it almost instantly goes off.
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 ![]() ![]() |
My steering wheel light also comes on when pushed and off when released but only recently, prior to this it stayed on until the ignition was turned off. So for a fix what has to be bought? Any links at all? Mines a 2005? |
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 ![]() ![]() ![]() |
Hi
