![]() | Home > Technical (L322) > HEATED STEERING WHEEL L322 VOGUE |
| v8rich Member Since: 28 Dec 2013 Location: Healing, Lincolnshire Posts: 67
I'm after a heated wheel 'ecu', for the final piece in my heated wheel upgrade.. |
Righto, will keep an eye out for that. It's a bit lower down the priority list atm. |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Thanks Mate, you've made my day |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Mine stays on till either switched of or ignition turned off and like Pete the stitching doesn't get too hot was only complaining to SWMBO about that this morning |
| Slow Member Since: 09 May 2015 Location: Inverness Posts: 39
Bit of a thread revival but, my heated steering wheel does exactly what you described. Press it on and it almost instantly goes off.
| Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212
My steering wheel light also comes on when pushed and off when released but only recently, prior to this it stayed on until the ignition was turned off. So for a fix what has to be bought? Any links at all? Mines a 2005? |
| babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142
Hi
| All times are GMT |
