![]() | Home > Maintenance & Mods (L322) > Drivers door dead locked |
What happens when you turn the key? If not do a battery reset... |
Rob Member Since: 17 Jan 2015 Location: south Posts: 6 ![]() ![]() ![]() |
Key opens and locks door perfect nothing when you pull handle door open okey with inside handle ??????? |
In that case you have a broken cable from outside handle to latch... Happens all the time on RR so do a search in the wiki for the fitting details sir... |
Thank you I may cancel test in the morning then. Hopefully an easy fix cheers again |
Your welcome... |
JEEP ? |
