|  | Home > Maintenance & Mods (L322) > Drivers door dead locked |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | What happens when you turn the key? If not do a battery reset... | ||
|  15th Feb 2015 7:00pm |
| Rob Member Since: 17 Jan 2015 Location: south Posts: 6      | Key opens and locks door perfect nothing when you pull handle door open okey with inside handle ??????? | ||
|  15th Feb 2015 7:07pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | In that case you have a broken cable from outside handle to latch... Happens all the time on RR so do a search in the wiki for the fitting details sir...  | ||
|  15th Feb 2015 7:09pm |
| Rob Member Since: 17 Jan 2015 Location: south Posts: 6      | Thank you I may cancel test in the morning then. Hopefully an easy fix cheers again | ||
|  15th Feb 2015 7:13pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Your welcome...  | ||
|  15th Feb 2015 8:01pm |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964      | JEEP ?  | ||
|  16th Feb 2015 12:59am |
| Posting Rules
