Home > Maintenance & Mods (L322) > Drivers door dead locked
Rob
Ireland 2005 Range Rover HSE Td6 Java Black
Hi big help needed done the two lower control arms today the drivers door was left open. Went for spin all was perfect with jeep. Just tried to get into jeep and drivers door won't open when I use fob I can hear locks opening and closing perfect but it is like it is dead locked all other doors are perfect
Post #312885 15th Feb 2015 6:48pm
What happens when you turn the key? If not do a battery reset...
Post #312889 15th Feb 2015 7:00pm
Rob
Key opens and locks door perfect nothing when you pull handle door open okey with inside handle ???????
Post #312892 15th Feb 2015 7:07pm
In that case you have a broken cable from outside handle to latch... Happens all the time on RR so do a search in the wiki for the fitting details sir... Thumbs Up
Post #312894 15th Feb 2015 7:09pm
Rob
Thank you I may cancel test in the morning then. Hopefully an easy fix cheers again
Post #312896 15th Feb 2015 7:13pm
Your welcome... Thumbs Up
Post #312910 15th Feb 2015 8:01pm
JEEP ? Shocked 2008 MY Supercharged
Post #312949 16th Feb 2015 12:59am
