![]() | Home > Maintenance & Mods (L322) > rear compartment heating |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 ![]() ![]() ![]() |
hi all, i wonder if anyone could shed light onto the fact that the ventilation duct on the central cubby box only blows out cold air. |
It looks as though the blend flap which controls the temperature of the air coming out of the rear vents is stuck for whatever reason.
thanks, will look into it |
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 ![]() ![]() ![]() |
Mine used to only blow out hot. It turned out to be a stuck valve in the "coolant valve unit" in the engine bay. This was diagnosed by my Indy, who found a mismatch in the coolant temperatures when it was running on live diagnostics.
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
mine also blows hot unless I turn the fan right up then blows cool/cold as set even when the fan is turned back down, sometimes need to change every journey sometimes not for a week. There is a difference between knowing your sh!t and knowing you're sh!t
Just shows how much I know then. I thought it was permanently cold to keep one's Snickers from melting |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
FOOL!
