Home > Maintenance & Mods (L322) > rear compartment heating
razzer
England 2003 Range Rover HSE Td6 Zambezi Silver
hi all, i wonder if anyone could shed light onto the fact that the ventilation duct on the central cubby box only blows out cold air.
Post #315530 1st Mar 2015 11:24am
Presumably all the settings are on hot? There is a rear FSR that fails! Search facility should cover this Thumbs Up
Post #315533 1st Mar 2015 11:32am
It looks as though the blend flap which controls the temperature of the air coming out of the rear vents is stuck for whatever reason.
This describes the control of the rear ac.
Post #315536 1st Mar 2015 11:51am
razzer
thanks, will look into it
Post #315575 1st Mar 2015 3:50pm
jon3929
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Mine used to only blow out hot. It turned out to be a stuck valve in the "coolant valve unit" in the engine bay. This was diagnosed by my Indy, who found a mismatch in the coolant temperatures when it was running on live diagnostics.
Cheers, Jon.
Post #315616 1st Mar 2015 7:47pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
mine also blows hot unless I turn the fan right up then blows cool/cold as set even when the fan is turned back down, sometimes need to change every journey sometimes not for a week. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #315671 2nd Mar 2015 11:17am
mzplcg
Just shows how much I know then. I thought it was permanently cold to keep one's Snickers from melting Laughing
Post #315682 2nd Mar 2015 2:07pm
johnboyairey
FOOL!
Post #315807 3rd Mar 2015 1:37am
