Home > Maintenance & Mods (L322) > Don't be fooled my an Mot !
Rangeyman
Finally having the bus parked up a couple of months,got the air suspension sorted and a new battery and straight through an Mot.The girlfriend and little one were excited at a trip to the supermarket.All piled in on the driveand I managed to travel a distance of 2 yards! Yes I did not get off the drive,a brake pedal that suddenly decided to travel then PING..Check brake fluid level,air suspension inactive,hdc inactive..What the F%$k!!Yes fluid leaking from half way down the vehicle,a common fault,yes I know now but if pipes are hidden by a plastic guard that is not removed for Mot should they be inspected for an mot?What would happen if I had just gone down a steep hill and had a serious accident with a new Mot?Surely this is something that needs addressing and not writing on the certificate 'plastic covers fitted' just to cover their arse!!! Anyway I did read somewhere a main dealers could renew the pipes for £700 but I thought that was a bit much so with a thanks to my mate Gary who helped me out it cost me a total of £15 for fluid and pipe!!!
Post #315642 1st Mar 2015 11:12pm
When i owned my SL55 they had to write off half the MOT due to "covers fitted" as the whole car has a plastic underfloor! Pointless! Rolling Eyes
Post #315647 2nd Mar 2015 12:20am
And the moral of the story is, strip off all the plastic covers hiding the brake pipes, coat the brake pipes with a thick layer of grease and refit the covers. Works everytime. Thumbs Up
Post #315664 2nd Mar 2015 10:02am
Joe wrote a very good post on renewing the brake lines that's now in the wiki.
Post #315665 2nd Mar 2015 10:13am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
As per my input to this post........
http://www.fullfatrr.com/forum/topic28819.html
The MOT guy I use is insistent that if the vehicle MOT is carried out properly on a FF there will ALWAYS be an advisory about the covers that they cannot see behind. I was quite disappointed as I was hopping for a clean "no advisory / nothing to report"
So if, God forbid, the worst had happened going down that hill you used as an example the MOT station "could" be in a sticky situation if they had not issued an advisory about the bits they cannot see.
My November 2014 MOT says:
001 Under-trays fitted obscuring some underside components
002 Engine covers fitted obscuring some components in the engine bay
I have seen a few comments on here of late "Passed MOT with no advisories!" and thought back to his words..... 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #315691 2nd Mar 2015 3:16pm
johnboyairey
on my old p38 there is the rear axle to body connection, from there going back to the pedal, the line failed, squirting like a tomcat! it was an afternoon to remove, and make up a pipe, and i inspected the rest, they were much better, but the old one coming off, was looking like a cancered worm, and snapped at any flexing. -and it had not long passed its MOT, and -it was visible! -top part of chassis..plenty of mud traps there. why dont they use kunifer, thats nickle plated copper, not cheap steel! the difference is pence
some garages, only let in a 1 foot length to repair old pipe. so if in doubt, renew and/or inspect after..
Post #315697 2nd Mar 2015 3:40pm
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Having helped Rangeyman to replace these Brakepipes I have 1 question.
Taking off the covers takes minutes and as these are known weak points
in the braking system and the possible consequences massive, why are the garages
not told to take the covers off to inspect?
Surely its a No-brainer??
Post #316835 8th Mar 2015 10:05am
Mine passed its MOT yesterday, with 10, yes 10 advisories! Shocked
They all said "corroded but not significantly weakened" on almost all the suspension components! Including a new component only replaced less than 2 weeks ago! Now, I know it's been wet and salty of late but this is just taking the p155! Censored
WTF???? Sounds like a small amount of surface rust seems worthy of mention but no mention of covers concealing check points?
Consistent? I think not! Got - 2017 SDV8 Autobiography in Loire Blue
Post #316841 8th Mar 2015 10:47am
It does seem strange that the MOT test excludes checking the condition of brake pipes year after year by way of the Mot tester being able to cop out by simply writing an "Advisory" when confronted by easily removable plastic covers.
Perhaps consideration should be given to a requirement that all such covers are removed by the owner prior to presentation for the test.
Interestingly you don't actually hear of many cases of accidents etc caused by failing corroded brake pipes, I only know of one case of a brake pipe failing under pressure and that fortunately was on a driveway.
Post #316864 8th Mar 2015 12:15pm
Mine failed on my old P38, sat on the ramp bleeding them whilst carrying out a routine service!
Bought a lotto ticket that night! Felt thoroughly LUCKY! Thumbs Up
Post #316867 8th Mar 2015 12:23pm
Did you win? Laughing Got - 2017 SDV8 Autobiography in Loire Blue
Post #316870 8th Mar 2015 12:25pm
Nah.... But I'm still here Alan Thumbs Up
Post #316871 8th Mar 2015 12:32pm
Very true Craig. Imagine you had the winning ticket and getting wiped out on the way home Rolling Eyes Got - 2017 SDV8 Autobiography in Loire Blue
Post #316885 8th Mar 2015 1:37pm
swmbo'd would have looked far more attractive though hay Whistle Laughing Laughing Laughing
Post #316886 8th Mar 2015 1:42pm
wealy
I have an advisory on my jag that there were "items on the seat so cannot check seatbelt" - When I questioned him and said why didn't you just move the box and put it on the other seat he said he can't touch it! I also have a friend who had an advisory about the sat nav "blocking" the driver view? as she had left Her TomTom stuck to the window????
Post #316897 8th Mar 2015 2:25pm
