Home > Maintenance & Mods (L322) > Interior courtesy lights won't turn off! |
mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169 |
I had the interior roof lining replaced in the car. When the car came back, the courtesy lights started to play up. When I lock the doors with the remote, the lights start to dim but immediately powers back on! Usually the lights will just fade away.
8th Mar 2015 8:23pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7647 |
I understand that holding the switch in turns them off, and again for manual on.
9th Mar 2015 12:38am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16187 |
I think what he had done is put your rear light in the front & visa versa... Although both interior lights appear to be identical they are NOT sir... The circuit boards have different hardware/software so behave differently if accidentally plugged back in the wrong way around...
9th Mar 2015 8:40am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34959 |
havnt the front and back interior lights have different plugs? ... - .- -.
9th Mar 2015 10:19am |
Absolutely SPOT ON! swapped the units around, re-set the battery and all systems back to normal! phew! Thanks for that amazing tip Craig! You are a champion! '01 1.8i Freelander. Grey/ grey '06 4.2 S/C Buckingham Blue/ Parchment '15 5.0 S/C SVA Loire blue/ Black |
9th Mar 2015 2:47pm |
Cheques made payable to ....................
9th Mar 2015 2:50pm |
LR should have made different plugs for the front and rear but the plugs are identical - just different colour. One is white, the other black! '01 1.8i Freelander. Grey/ grey '06 4.2 S/C Buckingham Blue/ Parchment '15 5.0 S/C SVA Loire blue/ Black |
Amazing! Many thanks again from a different time zone and many thousand miles away! '01 1.8i Freelander. Grey/ grey '06 4.2 S/C Buckingham Blue/ Parchment '15 5.0 S/C SVA Loire blue/ Black |
9th Mar 2015 2:53pm |
Your very welcome sir |
9th Mar 2015 2:58pm |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
If it weren't for this forum and the great contributors who help resolve many of the problems, I wouldn't contemplate running a RR out of manufacturers warranty |
9th Mar 2015 3:04pm |
9th Mar 2015 8:41pm |
