![]() | Home > Technical (L322) > Brakelights/Switch. L332 TD6 |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Where the codes cleared/reset after the new brake light switch was fitted?
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804
I think there may be a big hint in your last post, what year 'upgrade' lights are they, if they're LED light units, then do they possibly not need the extra wiring bits to make them work properly? If that's not been done, then that could be the root cause of the problem.
| Dazzler Member Since: 09 Sep 2013 Location: West Sussex Posts: 34
Thankyou will check bulbs yes codes were cleared.
No worries Dazzler, was just thinking that there was a post in the link mentioning HDC/ABS/Air Susp Inactive warnings coming up if the ballast resistors, extra wiring boxes, etc., weren't fitted. Thought that there might be a fault with a resistor or possibly the wiring which may be the culprit, especially if the lights have been in for 6 years plus. |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
what's a LCM, and is it fitted to the 08 tdv8?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
light control module...and yes you do have one. ... - .- -.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
We all have one |
