Home > Technical (L322) > Brakelights/Switch. L332 TD6
Dazzler
England 2003 Range Rover Vogue Td6 Zambezi Silver
Thankyou,
Is it right that the new LCM has to be Programmed to the FF?. I took mine to a so called specialist today and He wouldn't even touch it as I have upgraded supercharged LED rear lights. He will only work on standard cars. Sad
Post #317144 9th Mar 2015 7:16pm
Where the codes cleared/reset after the new brake light switch was fitted?
Are the brake light bulbs all seated correctly?
Post #317145 9th Mar 2015 7:34pm
Discotigger
I think there may be a big hint in your last post, what year 'upgrade' lights are they, if they're LED light units, then do they possibly not need the extra wiring bits to make them work properly? If that's not been done, then that could be the root cause of the problem.
Just done a quick search and got the following link:
http://www.fullfatrr.com/forum/topic14405....ear+lights
This may be of use Thumbs Up
Post #317149 9th Mar 2015 8:04pm
Dazzler
Thankyou will check bulbs yes codes were cleared.
Ive had the FF for 6 years now LED Lights were already fitted.Had no probs up and till now Sad .
Thanks for the link Thumbs Up
Post #317155 9th Mar 2015 8:36pm
Discotigger
No worries Dazzler, was just thinking that there was a post in the link mentioning HDC/ABS/Air Susp Inactive warnings coming up if the ballast resistors, extra wiring boxes, etc., weren't fitted. Thought that there might be a fault with a resistor or possibly the wiring which may be the culprit, especially if the lights have been in for 6 years plus.
Post #317159 9th Mar 2015 9:01pm
rar110
what's a LCM, and is it fitted to the 08 tdv8?
My L322 has standard tail lights. ______________________________
Post #317251 10th Mar 2015 11:35am
light control module...and yes you do have one. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #317252 10th Mar 2015 11:37am
We all have one Neutral Even Stan Mr. Green Laughing Thumbs Up
Post #317269 10th Mar 2015 12:58pm
