Home > Maintenance & Mods (L322) > Lumpy at 1600-1800rpms TDV8 -Sorted
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Folks,
Stopped off at shops then jumped back in car. After about 10 secs 'Engine Management Fault' on info centre. No EML light. No faults recorded on engine (IIDTool) except P132E-21 (unknown). Clearing faults makes no difference.
Seems very lump/juddery at between 16-1800 rpms on load. With a kind of asthmatic cough cough cough at the same time.
No other problems with engine before, 58K miles. I had just filled with diesel - it was diesel I put in.
Any readings I can take with the IID to see if this is EGR related or Turbo or split hose?
Cheers
Post #322342 12th Apr 2015 4:37pm
Mikey
Actuator live values and MAP live values
Post #322344 12th Apr 2015 4:42pm
stenh02
Post #322345 12th Apr 2015 4:53pm
stenh02
Mike, thanks, one is at 2500rpm other at idle so about 740rpm.
Do they look okay?
Post #322346 12th Apr 2015 4:54pm
Mikey
Both boost actuators have shut down. With the live data displayed, switch the engine off, and restart after a few seconds. The actuators should move through their range of travel.
Graphs may help here, rather than digital values Thumbs Up
Post #322347 12th Apr 2015 5:14pm
stenh02
(Image deleted)
No warning message this time when I started the car.
Post #322348 12th Apr 2015 5:33pm
Mikey
Both actuators appear to be working that time. I have a TDV8 with me just now, ill graph it in a bit Thumbs Up
EDIT: May also be worth checking the injectors comps too, just to rule out a misfire Thumbs Up
Post #322349 12th Apr 2015 5:36pm
stenh02
Thumbs Up Thanks Mikey. Will keep an eye on the injectors.
Post #322350 12th Apr 2015 5:45pm
Mikey
Both actuators should follow each other, and change with engine revs/MAP values. After start up and switch off, they should both go through a full cycle, so should see them both move Thumbs Up
Post #322357 12th Apr 2015 6:26pm
stenh02
Looks like mine (apart from mine cycle open and closed about 5 times after I switch the ignition off) Mike, thanks for running that.
Maybe we should delete the images with the VINs on.....
Cheers,
Post #322359 12th Apr 2015 6:30pm
sako243
Mine sometimes had similar symptoms but I would describe it more as it was trying to hunt for gears, would bounce up and down between 16-1800 lethargically, and sometimes cough if you put your foot down. Gearbox oil change seems to have sorted that out nicely.
May be completely different but might be useful info? Ed
Post #322376 12th Apr 2015 9:45pm
stenh02
Will check that as well.
The fault seemed to 'clear' itself. Drove fine this morning.
Just waiting for it to come back.....
Post #322392 13th Apr 2015 8:55am
stenh02
After being fine yesterday and this morning. After work got the engine management faul in info centre.
No codes seen with IDTool.
Seems Boost Pressure Actuator is stuck at 11% one side and 98% the other through all Rev ranges. (edit does that mean that gave just shut down as a precautionary measure?)
The EGR valves were still functioning and going thru the full range of movements.
Is this the start of turbo going duff or could it be the pipe work?
Cheers,
Edit 3- just found this on RRSport. Sounds similar.
http://www.rrsport.co.uk/forum/topic28628.html
Post #322601 14th Apr 2015 6:34pm
Mikey
I believe the one at 11% is stuck.
With the live data recording, start the car and watch the 2 traces. If the fault is present, one will move and one won't. Then both will settle, and stop moving
Had exactly the same.with an RRS yesterday Thumbs Up
Post #322608 14th Apr 2015 7:12pm
stenh02
http://www.fullfatrr.com/gallery/albums/us...32E21.tiff
Looks like a LH side one.
Prob just a sticky rod, will give it a look.
Thanks.
Post #322612 14th Apr 2015 7:26pm
