![]() | Home > Maintenance & Mods (L322) > Lumpy at 1600-1800rpms TDV8 -Sorted |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1849 ![]() ![]() |
Actuator live values and MAP live values |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
Mike, thanks, one is at 2500rpm other at idle so about 740rpm.
Both boost actuators have shut down. With the live data displayed, switch the engine off, and restart after a few seconds. The actuators should move through their range of travel.
(Image deleted)
Both actuators appear to be working that time. I have a TDV8 with me just now, ill graph it in a bit |
Looks like mine (apart from mine cycle open and closed about 5 times after I switch the ignition off) Mike, thanks for running that.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Mine sometimes had similar symptoms but I would describe it more as it was trying to hunt for gears, would bounce up and down between 16-1800 lethargically, and sometimes cough if you put your foot down. Gearbox oil change seems to have sorted that out nicely.
Will check that as well.
After being fine yesterday and this morning. After work got the engine management faul in info centre.
I believe the one at 11% is stuck.
http://www.fullfatrr.com/gallery/albums/us...32E21.tiff
