![]() | Home > Technical (L322) > Sump plug won't come out |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Hope that the old threads aren't just floating round the sump!
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
My thoughts exactly about it being the wrong bolt & this is the first time I've even looked at a L322 sump bolt. I'm now in two minds what to do, the bolt is back in & tight & I need to get the car moved off the drive ASAP to bring my classic back to go on the drive. But at the same time I hate things being bodged & it will bug hell out of me & also if I just put oil in to move it then if I do decide to sort it then that's a waste of a |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Put oil in and fix it when its next due an oil change |
Yes I think that's what I'll do |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I can't remember the thread of the Bmw engine - but I bought a clever magnetic tipped sump bolt a while back. I think I got it on eBay for about £4..... I googled the engine type to find it. This has a magnetic pull on your engine oil to hold swarf to be cleaned off at oil changes. -so you could buy another size up from the one you have, and tap a thread, using tap cutting grease. - that bolt in the pic looks very 'foreign' I think your stripped threads are on the end of the new bolt, stopping it from dropping out. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
That is an ordinary 8.8 high tensile bolt / setscrew which some idiot has put two copper washers on.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
^^ Wot he said, or you could tap it to 3/8" BSP which is 14.25mm ish, at least you'd be able to get a blanking plug in the bsp size. First I'd see if you can get an M14 blanking plug as that will require less material to be removed from the hole. Oh and be warned that metric treads come in different pitches, there are 4 |
You could try this
I was thinking if you have to go to the effort of recutting you sump thread how about going whole hog and fitting a quick drain plug ?
^^ Don't answer that, they have an application list that includes all the ffrr models |
That quick valve looks a good solution. I've actually screwed the plug back but it leaked slightly so I used jb weld RTV silicone round the plug for now. Was going to tackle it next time as lots more issues I'm trying to sort out but I may order one of those. 2004 RR 4.4 V8 Autobiography |
I would sort this as a TOP priority - If that fails and the bolt comes loose you could be in a world of s*** |
So, if you fit a quick drain valve, what is to stop you knocking it very time your under the car doing maintenance? And covering yourself in engine oil??? |
