Home > Technical (L322) > Sump plug won't come out
Page 2 of 4 <1234>
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Didn't know it was a cast sump, from a photo there is obviously something wrong, bolt doesn't look right in the hole.
I would maybe get a new sump plug from the dealers, then at least you will know whether what you have is right or not
You may then be able to identify the thread to maybe helicoil. Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #326585 7th May 2015 8:20pm
Hope that the old threads aren't just floating round the sump!
That is not the right bolt, it does look like someone has had a problem before and just bodged in a standard bolt. There is nothing that can't be fixed with a hammer😜😜
Post #326592 7th May 2015 8:52pm
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
My thoughts exactly about it being the wrong bolt & this is the first time I've even looked at a L322 sump bolt. I'm now in two minds what to do, the bolt is back in & tight & I need to get the car moved off the drive ASAP to bring my classic back to go on the drive. But at the same time I hate things being bodged & it will bug hell out of me & also if I just put oil in to move it then if I do decide to sort it then that's a waste of a Censored load of new oil. 2004 RR 4.4 V8 Autobiography
Post #326612 7th May 2015 10:44pm
Put oil in and fix it when its next due an oil change Whistle Whistle Whistle
Post #326623 7th May 2015 11:15pm
PaulM
Yes I think that's what I'll do Whistle
I'll drop a little oil in first to see if it leaks as a test, don't want to fill it right up to discover it's now leaking Shocked 2004 RR 4.4 V8 Autobiography
Post #326630 7th May 2015 11:30pm
johnboyairey
I can't remember the thread of the Bmw engine - but I bought a clever magnetic tipped sump bolt a while back. I think I got it on eBay for about £4..... I googled the engine type to find it. This has a magnetic pull on your engine oil to hold swarf to be cleaned off at oil changes. -so you could buy another size up from the one you have, and tap a thread, using tap cutting grease. - that bolt in the pic looks very 'foreign' I think your stripped threads are on the end of the new bolt, stopping it from dropping out.
Post #326634 8th May 2015 12:11am
wealy
That is an ordinary 8.8 high tensile bolt / setscrew which some idiot has put two copper washers on.
I'm guessing its M12 so you could tap it out M14 and repair it that way or get the nearest helicoil size up from it.
Post #326732 8th May 2015 4:44pm
miggit
^^ Wot he said, or you could tap it to 3/8" BSP which is 14.25mm ish, at least you'd be able to get a blanking plug in the bsp size. First I'd see if you can get an M14 blanking plug as that will require less material to be removed from the hole. Oh and be warned that metric treads come in different pitches, there are 4 Shocked 14 x 1.00, 14x1.25, 14x1.5 and 14x2.00 Yesterday I couldn't spell Engineer... Today I are one!
Post #326813 8th May 2015 10:50pm
miggit
You could try this
http://www.malpasonline.co.uk/itm/Metric-H...amE8J.dpbs Yesterday I couldn't spell Engineer... Today I are one!
Post #326814 8th May 2015 10:53pm
I was thinking if you have to go to the effort of recutting you sump thread how about going whole hog and fitting a quick drain plug ?
http://www.quickvalve.co.uk/ 2008 MY Supercharged
Post #326829 9th May 2015 2:15am
miggit
Bow down Bow down never seen one of those before, neat idea Bow down Bow down
The only draw back that I can see, is that it does not swivel, but in hind sight, that will turn out to be an advantage in this case, as you will have to glue the drain plug in the sump at the correct angle. If any of the threads have survived the assault from the chimp that bodged the sump plug, and presumably ate the original plug ( Shocked ), there would be no need to re-tap the sump. I would suggest the use of JB Weld to glue the plug in the sump, and you will have to use some de-greaser to clean the hole. Here I would recommend an aerosol of brake cleaner or carb cleaner, which will be an industrial alcohol based solvent, in a squirty can, so no problems with application Thumbs Up
The only other issue that I can foresee is, you will need to raise the car at an angle so that the sump plug hole is above the sump, otherwise the de-grease will take a life time as you clean out the whole sump Shocked Question Banging Head Thud Embarassed Embarassed
And obviously you'll have to do without the use of the car for a day while the glue sets Sad , but it's a small price to pay for never having the a55 ache of removing the sump plug again, and oil running down your arm will also be a thing of the past Mr. Green
I think that I will look in to fitting one of these, as I can only see advantages, and no draw backs. Does anyone know the original thread size used in the BMW sump (TD6)? Yesterday I couldn't spell Engineer... Today I are one!
Post #326863 9th May 2015 11:07am
miggit
^^ Don't answer that, they have an application list that includes all the ffrr models Very Happy
LOOK Bow down http://www.quickvalve.co.uk/f109n_details.htm
Even better, you fit a hose and make the old oil go where you want, and not where the wind will take it Thumbs Up Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #326865 9th May 2015 11:19am
PaulM
That quick valve looks a good solution. I've actually screwed the plug back but it leaked slightly so I used jb weld RTV silicone round the plug for now. Was going to tackle it next time as lots more issues I'm trying to sort out but I may order one of those. 2004 RR 4.4 V8 Autobiography
Post #327842 13th May 2015 11:36pm
wealy
I would sort this as a TOP priority - If that fails and the bolt comes loose you could be in a world of s***
Post #327851 14th May 2015 8:55am
So, if you fit a quick drain valve, what is to stop you knocking it very time your under the car doing maintenance? And covering yourself in engine oil??? Whistle
Post #327856 14th May 2015 9:21am
Page 2 of 4 <1234>
