![]() | Home > Technical (L322) > Tdv8 turbo failure |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1701 ![]() ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8483 ![]() ![]() ![]() |
Seems a massive job to get them out! Glad mine hasn't got a map on it, was thinking about it but decided not to, for that very reason.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3704 ![]() ![]() |
The only FFRR I would remap is a TD6 as they are under stressed and even BMW gave them a power upgrade in the later X5's.
GrantMundy Member Since: 12 Jun 2015 Location: Berkhamsted, herts Posts: 12 ![]() ![]() ![]() |
As far as I know it's never been mapped. I do wonder if it is servicing though. It was due one when I bought it. So did one shortly afterwards. Im waiting to hear from someone in the know from jlr aswell about the turbos
Also, was lucky, friend of mine had a brand new turbo from Land Rover in stock on the shelf (passenger side). Was stock that he wrote off earlier this year.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16192 ![]() ![]() ![]() |
Any further news on this yet please? |
Hi all,
As I've said plenty of times previously then... EGR over speeds turbo and bang!
According to midland turbos they get a set in every other week with the same problem. I'm going to blank the egr's off at the same time, just hoping it won't bring up the MIL light on the dash. Any body know if it will?
You will need them mapping out I'm afraid sir |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6672 ![]() ![]() ![]() |
Just out of interest hiow much did they charge to rebuild the turbos? Got - 2017 SDV8 Autobiography in Loire Blue
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
So nothing to do with having a map then, egr is the culprit. hmmmm.
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 155 ![]() ![]() ![]() |
surely it should be viewed in the same way as the Disco/Sport oil pump failures if you change the front casing on those engines and o it as a proactive work scope you avoid issues, in the TDV8 you proactively change the EGR valves and do the inevitable while your in there jobs and then respect the run down process as you should for any Turbo engine and you then avoid problems? |
