Home > Technical (L322) > Tdv8 turbo failure
Page 3 of 4 <1234>
Vogue
Do you know if she has been mapped in a past life - this is probably the most likely cause. I know of many turbos which have lasted 150 to 300k miles no issues with regular oil changes / servicing and being allowed to spool down after a run 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #332494 14th Jun 2015 7:53pm
Mikey
This is my theory on why TDV8 turbos let go frequently Thumbs Up
Post #332513 14th Jun 2015 9:23pm
Seems a massive job to get them out! Glad mine hasn't got a map on it, was thinking about it but decided not to, for that very reason.
Though If one of the op's units shows significant spindle wear, that could point to some level of oil starvation in the past, which might not point to a remap issue, more an oil feed problem. There is nothing that can't be fixed with a hammer😜😜
Post #332517 14th Jun 2015 9:31pm
Vogue
The only FFRR I would remap is a TD6 as they are under stressed and even BMW gave them a power upgrade in the later X5's.
I wouldn't entertain a map on a TDV8 - not only speaking from personal experience, but also advice from a contact on the inside at LR - who even ditched his own mapped TDV8 before she lunched on her Turbo's.
Generally Turbo's unless they are messed with are very reliable, its people messing with boost pressure and fuelling that fooks them up. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #332529 14th Jun 2015 10:38pm
GrantMundy
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
As far as I know it's never been mapped. I do wonder if it is servicing though. It was due one when I bought it. So did one shortly afterwards. Im waiting to hear from someone in the know from jlr aswell about the turbos
It wasn't too bad to be fair, first evening I had a friend with me, so we spent a few hours assessing it and thinking of trying to do it without. Then we just started underneath, hardest part was the strut bolts seized in solid to the point of a scaffold tube, breaker bar and a sledge hammer Shocked. Then the next day I did the box end and then unbolted the lot and sat it on the trolley. Took a bit longer than expected as it was the first time, but I reckon you could drop the whole lot if I was to do it again in 3/4 hours comfortably
Post #332537 15th Jun 2015 12:36am
GrantMundy
Also, was lucky, friend of mine had a brand new turbo from Land Rover in stock on the shelf (passenger side). Was stock that he wrote off earlier this year.
Best £350 I've spent this year! Laughing. Genuine Borg Warner unit!
Post #332542 15th Jun 2015 1:15am
Any further news on this yet please?
Post #334118 23rd Jun 2015 7:44pm
GrantMundy
Hi all,
Yep, have some news, the turbo I got from my friend was wrong Crying or Very sad . So I sent my pair off to be rebuilt.
Midland turbos rebuilt them, absolutely amazing company if I may say so, really quick, really informative. Have used them a few times before.
They suspected that what had happened is the left hand turbo had over spoiled from they reckon an egr fault, and it 'detonated' as such, and filled the other one with oil.
Have both back now all shiny! And a few boxes of other bits. Il try and take some more
Piccis later for anyone interested
Cheers
Grant
Post #334201 24th Jun 2015 12:37pm
As I've said plenty of times previously then... EGR over speeds turbo and bang!
Sorry to hear your the latest victim... But glad it's getting sorted sir...
Thanks for the update Bow down
Another BIG +1 for Midland Turbo's Thumbs Up good knowledgable guys Bow down
Post #334208 24th Jun 2015 1:36pm
GrantMundy
According to midland turbos they get a set in every other week with the same problem. I'm going to blank the egr's off at the same time, just hoping it won't bring up the MIL light on the dash. Any body know if it will?
If it does il have to get it mapped out
Post #334221 24th Jun 2015 3:33pm
GrantMundy
Post #334222 24th Jun 2015 3:34pm
You will need them mapping out I'm afraid sir Rolling Eyes
Post #334224 24th Jun 2015 3:46pm
Just out of interest hiow much did they charge to rebuild the turbos? Got - 2017 SDV8 Autobiography in Loire Blue
Post #334237 24th Jun 2015 5:09pm
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
So nothing to do with having a map then, egr is the culprit. hmmmm.
Are we saying its a luck thing wether or not yours is the one (or 2) that goes?
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #334258 24th Jun 2015 7:34pm
Trantorman
United Kingdom 2017 Range Rover Vogue SE SDV8 Aleutian Silver
surely it should be viewed in the same way as the Disco/Sport oil pump failures if you change the front casing on those engines and o it as a proactive work scope you avoid issues, in the TDV8 you proactively change the EGR valves and do the inevitable while your in there jobs and then respect the run down process as you should for any Turbo engine and you then avoid problems?
Post #334331 25th Jun 2015 7:12am
Page 3 of 4 <1234>
