![]() | Home > Maintenance & Mods (L322) > Window film on rear side windows |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
No comments? So ls that clear film normal and used to apply the antenna? I thought they would have been inside the glass. |
Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67 ![]() ![]() ![]() |
You can normally feel the aerial wires on the "inside" face of the glass. They are not embedded in the glass.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
The factory tint isn't a film. The actual glass is tinted afaik, the way to check is if you can obviously see the heated screen elements from the outside of the car then it is an aftermarket tint. If you can't see them then it is factory.
Thats what i want |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
it might be to protect the glass (and radio aerials) from being scratched by dogs in the back or something.
Thanks northernmonkeyjones
