![]() | Home > General > jacks.. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
140nm's tim... ... - .- -.
| Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313
I always put my wheel nuts on with a rechargable impact gun, then torque them up with a bar. |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Then re-check then later that day or the next day |
In theory yes. But don't do a daily defect check every day before I use the vehicle. |
| Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181
Thanks for the torque, I thought it was that but haven't seen it anywhere - Defender and RRS are the same. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Something I learned from the master technician at the shop where I was working at 17. All steel (wheels, lugs) and a powerful impact gun/good compressor - then maybe, just maybe w/o a torque wrench after hitting each lug twice with the impact (and knowing that if the owner has a flat the ugly language will be thick). Otherwise always click each lug.
RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
i used to do nuts up with a windy gun and got them done up with just the right torque, mind you 23 years in the tyre trade helped me judge how long to press the windy gun trigger..... ... - .- -.
| Discocuzzy Member Since: 02 Aug 2010 Location: Surrey Posts: 94 |
Takla air jack |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325
Scarey, Mine is an Arcan XL35R 3.5t jack, lift height according to the spec's is around 55cm
thanks mark, i thought that i might need something in the region of a 55cm lift .. ... - .- -.
It's about time LR designed a compressed air outlet into the boot so you can use compressed air tools and jacks using the car's own compressor off road 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Mind you, that just say lifts the wheels off the ground enough to get them off! 2006 Mercedes CLS 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
mark, do you lift on the chassis or the jacking points just below the doors... ... - .- -.
To be honest, I've only used it once on the RR and that was when I first got it (when I took the pics) so I can't remember where I jacked it from, I think from the jacking point below the doors. I need to whip the wheels off anyway to clean the dirt off wheel arch liners anyway, I'll try from the chassis and see if it lifts any higher. 2006 Mercedes CLS
| All times are GMT |
