Home > Technical (L322) > L322 4.4 keeps coming up reduced engine performance
pld118
All I can tell you budha is this (and I know not if it assists you) Thumbs Up
Whilst driving home on the motorway my wife reported that the 4.2SC lost power and at the same time she got a Reduced Engine Performance dashboard warning. That fault cleared after the car was switched off and re-started. Main dealer said they later plugged the diagnostic tool into the car and the reason for the reduced engine performance was because the water pump had failed (connected to the supercharger I think/ mechanic said it was a known issue on the SC). They replaced the water pump and associated cabling.
http://www.fullfatrr.com/forum/topic24398-30.html
Post #339402 27th Jul 2015 8:06pm
budha
England 2006 Range Rover Autobiography 4.4 V8 Java Black
OK thanks
Post #339736 29th Jul 2015 4:24pm
nemmi69
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Barolo Black
Is this an SC? If so you may need to check the aux water pump used for intercooler cooling.
Post #339859 30th Jul 2015 7:24am
budha
No vogue 4.4 petrol
Post #340284 1st Aug 2015 3:55pm
TugRR
As stated before, Budha, I had this on & off for a year with my last FF. Crucially (!) with the same engine as yours . . .
All sorted with a new MAF sensor - I know you mention you've had this replaced but I'd try another as it sorted my problem completely -
Thumbs Up Where do you go after one of these . . . ?
Post #340332 1st Aug 2015 8:32pm
budha
OK thanks will have to try again
Post #340515 3rd Aug 2015 9:44am
budha
Just spoke to someone who says maybe an air leak so smoke test and software update might do it. Fingers crossed.
Post #342516 14th Aug 2015 5:15pm
Zirconblue
a bit of air intake (carb) cleaner through the maf wont do any harm. Over time they can get a build up of fine dirt on them.
Post #342557 14th Aug 2015 7:47pm
Knightmare
England 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
I had this very same problem yesterday on my 4.2SC. Admittedly I was being fairly heavy with the right foot at the time on the motorway (late again), but the warning 'Reduced Engine Performance' flashed up on the dash with an audible alarm. From that moment on, the power was indeed reduced. Kept cruising at 70 very happily, but if I went to put my foot down to overtake...nothing happened. Got to where I was going and parked up for around 4 hours...after that (and fingers crossed) it seemed fine. Neutral
Will monitor and get the aux water pump checked. Life is what happens while you�re making other plans.
Post #343267 19th Aug 2015 11:59am
dingg1
You'll get that on a misfire , the ecu cuts off the fuel to the cylinder/s which have logged as misfired and the reduced performance bongs then disappears , all becomes good again after switching off the engine.
Post #343273 19th Aug 2015 12:18pm
Knightmare
Ah, ok. Thanks.
Is this something I should be overly concerned about? I mean it's obviously not an ideal situation, but should I get it looked at ASAP, or is it one of those things that can probably be monitored for a while? Life is what happens while you�re making other plans.
Post #343281 19th Aug 2015 2:20pm
Could get the codes read, should have stored one.... could be a coil pack breaking down, they tend to go intermittent before finally breaking... that's the usual fault item... Thumbs Up Pete
Post #343297 19th Aug 2015 3:25pm
budha
Had software update and smoke test. No leaks found. Terraclean done........still fault remains but car goes like stink. Getting frustrated now.
Post #345929 3rd Sep 2015 8:23pm
