![]() | Home > Technical (L322) > L322 4.4 keeps coming up reduced engine performance |
All I can tell you budha is this (and I know not if it assists you) |
budha Member Since: 03 Feb 2011 Location: london Posts: 27 ![]() ![]() ![]() |
OK thanks |
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 104 ![]() ![]() ![]() |
Is this an SC? If so you may need to check the aux water pump used for intercooler cooling. |
No vogue 4.4 petrol |
OK thanks will have to try again |
Just spoke to someone who says maybe an air leak so smoke test and software update might do it. Fingers crossed. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
a bit of air intake (carb) cleaner through the maf wont do any harm. Over time they can get a build up of fine dirt on them. |
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 ![]() ![]() ![]() |
I had this very same problem yesterday on my 4.2SC. Admittedly I was being fairly heavy with the right foot at the time on the motorway (late again), but the warning 'Reduced Engine Performance' flashed up on the dash with an audible alarm. From that moment on, the power was indeed reduced. Kept cruising at 70 very happily, but if I went to put my foot down to overtake...nothing happened. Got to where I was going and parked up for around 4 hours...after that (and fingers crossed) it seemed fine. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1391 ![]() ![]() |
Ah, ok. Thanks.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8699 ![]() ![]() ![]() |
Could get the codes read, should have stored one.... could be a coil pack breaking down, they tend to go intermittent before finally breaking... that's the usual fault item... |
Had software update and smoke test. No leaks found. Terraclean done........still fault remains but car goes like stink. Getting frustrated now. |
