![]() | Home > Technical (L322) > Air reservoir |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Mines alloy, 2003, and looks like new... I expect it was a cost issue.... Pete
Mines steel 2004. Even though it's behind a cover had mild surface rust patches on lower surface.
Surely the ally unit would save a few kilos as well. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I expect it would probably be quite thick ally, but then again on a 3 ton car it's probably not going to make a vast difference to economy or performance. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Are but it will make a major difference to JLR, I imagine that they are saving 60% + on the cost by using steel. Plus the steel unit will succumb to the tin worm quicker, leading to enthusiastically over priced replacements |
I've noticed the Ally ones are BMW sourced (made in Austria) whereas the Steel ones are UK sourced, going by the labels on them.
