Home > Technical (L322) > Air reservoir
Zirconblue
Air reservoir
I've noticed looking at second hand air reservoirs on ebay.
Early ones are aluminium, and later ones are steel.
Were there problems with the aluminium ones or were they just replaced with steel for cost reasons.
Considering the steel ones rot horrendously, replacing the rust one with an ally one seems to be a good idea on paper.
Post #339755 29th Jul 2015 7:16pm
Mines alloy, 2003, and looks like new... I expect it was a cost issue.... Pete
Post #339777 29th Jul 2015 8:41pm
Mines steel 2004. Even though it's behind a cover had mild surface rust patches on lower surface.
I just rubbed down, repainted in situ and then gave it a coat of grease.
If I had the choice I would go for aluminium purely on the grounds of minimising corrosion problems.
Post #339865 30th Jul 2015 8:04am
mzplcg
Surely the ally unit would save a few kilos as well.
Post #339867 30th Jul 2015 8:13am
Zirconblue
I expect it would probably be quite thick ally, but then again on a 3 ton car it's probably not going to make a vast difference to economy or performance. Laughing
Post #339914 30th Jul 2015 2:16pm
miggit
Are but it will make a major difference to JLR, I imagine that they are saving 60% + on the cost by using steel. Plus the steel unit will succumb to the tin worm quicker, leading to enthusiastically over priced replacements Censored 's Yesterday I couldn't spell Engineer... Today I are one!
Post #339976 30th Jul 2015 8:14pm
Zirconblue
I've noticed the Ally ones are BMW sourced (made in Austria) whereas the Steel ones are UK sourced, going by the labels on them.
So i would imagine the steel ones are MUCH cheaper.
When i get around to replacing mine i'll go for an Ally one i think.
Post #339983 30th Jul 2015 9:18pm
