![]() | Home > Technical (L322) > Air reservoir |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Mines alloy, 2003, and looks like new... I expect it was a cost issue.... Pete
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Mines steel 2004. Even though it's behind a cover had mild surface rust patches on lower surface.
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Surely the ally unit would save a few kilos as well. |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
I expect it would probably be quite thick ally, but then again on a 3 ton car it's probably not going to make a vast difference to economy or performance. |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Are but it will make a major difference to JLR, I imagine that they are saving 60% + on the cost by using steel. Plus the steel unit will succumb to the tin worm quicker, leading to enthusiastically over priced replacements |
I've noticed the Ally ones are BMW sourced (made in Austria) whereas the Steel ones are UK sourced, going by the labels on them.
| All times are GMT |
