![]() | Home > Maintenance & Mods (L322) > angel eye fogs/drls |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
unless you have a halogen in one fog and one of these cobs in the other it would be difficult to judge that one pieter...when i have time i'll disconnect my drls and switch the cobs on separately and see..
I don't think you need to worry. Splicing into the headlight cable, which ever you chose, only means you are adding a very small inductance circuit ( relay coil ) in parallel with a very high inductance circuit ( headlight ) which in practical terms means next to nothing. I can't see why it should upset anything, certainly didn't on mine and no-one else who has done it has reported a problem. |
as david says..i did on my td6 and my SC.. ... - .- -.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1393 ![]() ![]() |
This thread has spurred me into ordering the bits to convert my headlights by adding 2 led halos as DRL's , and change my side light bulbs to LED's .
this will be interesting , splitting the headlight seems to be the biggest problem... looking forward to the end results.. |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Hi,
the flickering could be down to the hot & cold bulb monitoring that the FF has...i've switched mine off with my iidtool..
Hmm.. Could be the case indeed...
i have my halos are connected to a drl switch which isnt part of the FF's wiring loom so no flickering..how is yours connected up Pieter... ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Stan, unless you turn off the H & C monitoring they will always have issues, even through a DRL relay |
Stan, for testing purposes I wired them into the old fog light connector.
Pieter, without the car in front of me i couldn’t tell you 100% but yes i would expect you will still have issues even using resistors sir... |
Ok... Any way of turning H&C monitoring off without having an IIDtool? 2002 L322 V8 |
Would it not be possible to feed the offending flickering lights through relays using the existing fog light wiring to switch the relays and feeding the LEDs by way of a separate fused circuit direct from the battery?
