![]() | Home > Maintenance & Mods (L322) > angel eye fogs/drls |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Sounds logical David.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35703 ![]() ![]() |
it does sound like hot and cold monitoring causing the flickering Pieter...you wouldnt go wrong in investing in an iidtool tbh.. ... - .- -.
Something like this,
Already bought one of these (from your earlier post) will buy another...
5A should be ok, led's are normally only only 3-4W usually. |
David,
If you have Hid headlights as opposed to tungsten halogen there is an ignition switched wire to each headlight. I used one for my Drl's. Can't remember the colour of the wire but I can have a look in the morning in daylight for you. |
http://www.fullfatrr.com/forum/post117872.html#117872 ... - .- -.
Thanks both!
i like the idea of the light adjustment, nice one Pieter...
Unfortunately tungsten headlights don't have an ignition feed.
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
Tx -again- David! |
