![]() | Home > Technical (L322) > Tdv8 puff of smoke |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
Black smoke or blue? Almost regardless, if the updated secondary turbo drain hasn't been fitted then get the dealer to do it before the end of warranty as its quite a job. |
Go to the dealer with it sir... NO question! |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Secondary turbo drain time..... Should be done FOC by the dealer as it is a known problem. There is nothing that can't be fixed with a hammer😜😜
| Andrew5331 Member Since: 26 May 2015 Location: Southlanarkshire Posts: 74
thanks guys its booked in for next monday ill let you know how i get on |
Got the car back last week
Turbo feed pipe I guess... Engine out job |
| Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284
Is this only on the 4.4's or does it cover 3.6's? And how do you know if it's been carried out? Ta |
Only on the 4.4 sir... |
Thank you |
Craig or any one else who may know what do you think that would have cost me if it hadn't been fixed under warranty |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
Your dealer in Glasgow has a labour rate of a little over £100 per hour. Wouldn't have been a cheap fix |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Warning - Most LR dealers will not do the Drain Mod outside of warranty period. Even LR Customer Service said NO. This is daft as its a known engineering fault and its nobody's fault but Land Rover. £1000 labour alone. |
I think you can probably double that labour amount Gaz, if it's 18 hrs... Pretty sure Stratstone's are over £130 an hour now |
| All times are GMT |
