![]() | Home > Technical (L322) > Tdv8 puff of smoke |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
Black smoke or blue? Almost regardless, if the updated secondary turbo drain hasn't been fitted then get the dealer to do it before the end of warranty as its quite a job. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Go to the dealer with it sir... NO question! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Secondary turbo drain time..... Should be done FOC by the dealer as it is a known problem. There is nothing that can't be fixed with a hammer😜😜
Andrew5331 Member Since: 26 May 2015 Location: Southlanarkshire Posts: 74 ![]() ![]() |
thanks guys its booked in for next monday ill let you know how i get on |
Got the car back last week
Turbo feed pipe I guess... Engine out job |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Is this only on the 4.4's or does it cover 3.6's? And how do you know if it's been carried out? Ta |
Only on the 4.4 sir... |
Thank you |
Craig or any one else who may know what do you think that would have cost me if it hadn't been fixed under warranty |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
Your dealer in Glasgow has a labour rate of a little over £100 per hour. Wouldn't have been a cheap fix |
Warning - Most LR dealers will not do the Drain Mod outside of warranty period. Even LR Customer Service said NO. This is daft as its a known engineering fault and its nobody's fault but Land Rover. £1000 labour alone. |
I think you can probably double that labour amount Gaz, if it's 18 hrs... Pretty sure Stratstone's are over £130 an hour now |
