Home > Technical (L322) > Tdv8 puff of smoke
Andrew5331
Tdv8 puff of smoke
Hi looking for some advise from seasoned full fat owners I've had my 2012 4.4tdv8
For a few months now but I've noticed that when I drop the hammer there is a cloud of
Smoke that comes from the back end
I must point out that neither myself or the good lady drive it hard
But I've noticed that this is there when I am heavy on the right foot
Also the car won't be 3 years old until the end of next month do you think that I should get it in to Land Rover or is this
Normal
Thanks
Post #345173 30th Aug 2015 9:16pm
GraemeS
Australia
Black smoke or blue? Almost regardless, if the updated secondary turbo drain hasn't been fitted then get the dealer to do it before the end of warranty as its quite a job.
Post #345179 30th Aug 2015 10:05pm
Go to the dealer with it sir... NO question!
Post #345193 30th Aug 2015 11:25pm
Secondary turbo drain time..... Should be done FOC by the dealer as it is a known problem. There is nothing that can't be fixed with a hammer😜😜
Post #345225 31st Aug 2015 9:07am
Andrew5331
thanks guys its booked in for next monday ill let you know how i get on
Post #345292 31st Aug 2015 1:00pm
Andrew5331
Got the car back last week
It has been fixed under warranty they said it was booked in as a 18 hr job so god knows what it would have cost with parts as well
So all in all I'm happy they fixed it
Post #348832 21st Sep 2015 9:13pm
Turbo feed pipe I guess... Engine out job Rolling Eyes
Post #348837 21st Sep 2015 9:43pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Is this only on the 4.4's or does it cover 3.6's? And how do you know if it's been carried out? Ta
Post #348845 21st Sep 2015 10:37pm
Only on the 4.4 sir...
Post #348848 21st Sep 2015 11:05pm
Lad
Thank you Thumbs Up
Post #348850 21st Sep 2015 11:06pm
Post #348851 21st Sep 2015 11:13pm
Andrew5331
Craig or any one else who may know what do you think that would have cost me if it hadn't been fixed under warranty
Post #348857 21st Sep 2015 11:39pm
Mikey
Your dealer in Glasgow has a labour rate of a little over £100 per hour. Wouldn't have been a cheap fix Shocked
Post #348863 22nd Sep 2015 6:55am
Warning - Most LR dealers will not do the Drain Mod outside of warranty period. Even LR Customer Service said NO. This is daft as its a known engineering fault and its nobody's fault but Land Rover. £1000 labour alone.
Post #348864 22nd Sep 2015 8:00am
I think you can probably double that labour amount Gaz, if it's 18 hrs... Pretty sure Stratstone's are over £130 an hour now Shocked my math tells me that's £2350.00 before extras & VAT so probably the thick end of £3000 Shocked
Post #348867 22nd Sep 2015 8:16am
