Home > Maintenance & Mods (L322) > Retrofit heated steering wheel?
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
Anyone know if its possible to retrofit a heated steering wheel to a ff that wasnt equipped with it from factory?
My dads thinking of buying a germany imported 3.6 -08 but he wants the heated steering because of our nordic climate...
Cheers L322 Vogue 2003
Post #346458 7th Sep 2015 9:24am
I can't see it being hard to retrofit the parts... Your biggest issue maybe changing the CCF...
Post #346463 7th Sep 2015 9:41am
Zirconblue
Are they not equipped with them as standard in Germany? I think HSE and above all have them as standard in the UK.
Post #346506 7th Sep 2015 3:51pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
HSE doesn't have a heated steering wheel Zircon, at least not as standard.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #346620 8th Sep 2015 9:35am
my 05 td6 HSE didnt have a heated steering wheel... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #346621 8th Sep 2015 9:37am
Zirconblue
Must be Vogue and above then.
Post #346625 8th Sep 2015 10:12am
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
My 2003 HSE has a heated steering wheel so yes it is possible.
Can't tell you how to do it as I bought the car with it already installed.
Mate just bought an aftermarket heated wheel for his HSE and has managed to get it working (think the original button on his old wheel turned on the aircon so there is still power going to that button location, just tap into that!) Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #347185 11th Sep 2015 11:56am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
The heated steering wheel is controlled buy a small Ecu under the airbag it's not just a switch and a power supply. Non heated steering wheel vehicles use the heated button to turn on the air circulation.
Matt
Post #347246 11th Sep 2015 5:50pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
You will need the slip ring cassette from a vogue as there are no connections in the one fitted to the HSE, also a relay which is fitted into the back of the fuse board in the glovebox and the switch pack on the steering wheel.
Stewart.
Post #347303 11th Sep 2015 10:10pm
