![]() | Home > Technical (L322) > Headlights Dazzling |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16343 ![]() ![]() ![]() |
Lots complain about it |
Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172 ![]() ![]() ![]() |
Excellent, Thanks Craig. Is the switch in the same location as my old Jag S type R? Top of the headlamp unit? |
plastic bulb cover thingy off then a lever next to the square xenon bulb unit sir |
This may help?
Just found this too... |
Brilliant Thank you! Just gone out to to move the lever and guess what happened?
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
Has it snapped Under the bonnet or Inside the car? Ours snapped Inside the car but the cable shot Inside the engine compartment, it was a dealer job to replace the cable as there is no way to open the bonnet, unles someone here knows a method. |
It has snapped inside the car. The Cable is fine but the Lever has snapped off it's retainer. Is that what happened to you? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35706 ![]() ![]() |
this any good Kev?
No, on ours the cable snapped where it enters through the bulkhead, if you can still grab the inner cable you'll still be able to open the bonnet. |
Thanks Paul & Stan, I will see how much LR quote for a replacement and then take it from there. Will let you know. The Cable is still attached to the mechanism so hopefully I will be safe!! |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
When you have fixed the bonnet cable (and that is easy if its broken at the handle. World of |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
It's not an MOT failure to have a flat beam as long as it still won't cause dazzle.
I agree on adjusting it properly though anyway. ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Ace thanks guys. Will adjust properly. Thanks for the advice! |
