![]() | Home > Maintenance & Mods (L322) > Replacement High Beam Bulb |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3912 ![]() ![]() ![]() |
My car has xenon dipped but main beam is a halogen bulb. The xenon is "cold" and the halogen is "warm" or blueish and orangeish if you prefer. whats the best choice for replacing the halogen to achieve a more blue light?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35721 ![]() ![]() |
i use normal 55 watt white halogens , loads on ebay at around £8 for the pair.....
Thanks Stan, it's not entirely lost but I probably notice it because it's as orange as Dale Wintons tan: in fact it's a lot like Dale Wintons tan, brings little to the party apart from an orange glow |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It's not really a 'main beam', because they're Bi-xenons - the xenon does both the main and low beam by way of a motorised shutter, that masks off part of the beam when you 'dip' them.
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
The shutters are pretty instant, but since HID takes time to warm up, it's unable to flash when the lights are off, so the halogen is there for that too.
Thanks for the replies but I probably need to add that I realise that this is only a cosmetic change and the the "main beam" halogen does little or nothing compared to the bi-xenons. So the posts confirming that are a bit superfluous to my needs, all I want is a bulb recommendation for the H7s so that the colour is similar to the xenons. |
i got something like these Geoff,
Excellent, thanks Stan. |
@ CTC,
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I think these are the bulbs CTC is on about, I had some in a car a few years back and they are a lot whiter than std. |
Ditto the above, and also for the reasons I posted above, but if you really want to go for an HID kit, make sure it's a decent one, like these: http://www.hids4u.co.uk/h7-xenon-hid-conversion-kits/ (DISCO315 |
I've just gone for a set of Stan's ones cos they is shiny and I'm a tightwad |
I just fancy the idea of significantly more light on the front end without resorting to auxiliary lamps. I never flash headlights at anyone so that's not a problem. As the conversion would only be on the main beam, causing glare to other road users shouldn't be a problem either.
